Poly ARB bushes
  • Christophski
    • 3632
    Poly ARB bushes
    ... Ok guys... how the hell do you fit the poly anti roll bar bushes? The hole in the bush is round and the ends of the arb's are not.... Is it a case of grease it up and give it a good whack??? (Wow, the amount of times I have greased it up and given it a good whack... but im getting side tracked now)
    Thanks....
  • irishs2
    • Apr 2009
    • 2455
    Dont the bushes have a split on them and you just open them up over the arb.
    Eric
    95 S2 Avant under rebuild.
    • Christophski
      • 3632
      Not that ive noticed Eric but if there isnt one I will make one... They are Powerflex ones, the same as the one in your picture. Im sure a stanley knife will sort the issue out for me.
      • irishs2
        • Apr 2009
        • 2455
        I just had a look at my set for the avant, and they dont have the split. So I think I am wrong.
        You just slide them over the ends over the arb., I just did it just now. Mine were 26mm.
        Eric
          They definitely used to have a split in them.
          did you get the right size Chris?
          • irishs2
            • Apr 2009
            • 2455
            I thought that for the coupe, but wasnt sure, and when my "new" ones (bought 4 years ago) didnt have the split I had doubts.
            Even though the ends of the arb are flat, they ends are not wider than the arb itself.
            Eric
            • martinws
              • Oct 2008
              • 917
              Mine had a greased up slit for sure. Didn't have to whack it though, just spread the slit wide n rammed it home.
              • andy10v
                • 5996
                Poor old girl
                Sold ABY-stock
                • AndyP
                  • 6049
                  Hope he doesn't treat his women like his car!
                  • Christophski
                    • 3632
                    I hope I got the right ones but I'm not sure then. I measured the bar and ordered the ones I thought were the right size... It's an rs2 arb I have
                      You need 28mm ones then, you sure that's what you got mate?
                      • Christophski
                        • 3632
                        Umm I will need to check when i get home later... I hope I got the right ones if not it looks like a journey back to the supplier and getting the correct ones...
                        • Christophski
                          • 3632
                          I think thats the front one bud isnt it? I think the rear ones are 16mm? The Powerflex website only lists up to 16mm anyway... I already had a set a friend got me as a gift that dont fit which are the ones ive been trying. I think they are a 15mm though....
                          • s2driveruk
                            • 12696
                            mine on the front for the rs2 arb did have a slit in them. Not sure I'm that convinced they make much difference if i'm honest
                            1992 3b S2 Coupe
                              Ah OK we're talking about a rear bar bush!
                              Can't comment then not familiar with the avant I'm afraid
