Help with brakes !!
  • Martin62
    • Jan 2011
    • 187
    Help with brakes !!
    So,
    I've been having an issue with one of my rear brakes binding on my 20v Quattro.
    On a couple of occasions the pedal almost went to the floor and needed pumping to stop the car, I assume due to overheated fluid. The wheel didn't feel too hot and the disc wasn't glowing so I was a little surprised.
    Strangely, once cooled as was normal again, except for the binding.
    I have rebuilt the offending caliper and all is ok now with one exception, the brake bomb seems to be shot !
    Pedal is rock hard on first start up of the day and warming light comes on autocheck for 5 seconds or so until pressure is restored.
    Can this be caused by air still being in the system ?
    I have realised that I didn't bleed the master cylinder just the calipers, could this be the cause ?
    I must admit this car is trying my patience at the moment !
    Any suggestions ?
    Cheers,
    Martin
    Don't know your issue but 5 seconds of brake bomb light is not one of them.
    You can't/don't need to bleed the master cylinder unless it was totally empty of fluid. Even then, the bleeding involves pushing all the air bubbles out to the calipers/wheel cylinders. People often use a different coloured brake fluid when doing a major bleed/fluid replacement so they know when the new fluid is coming through (otherwise the fresh stuff will be more clear/less brown than the old stuff).
    Proper brake bleeding starts at the wheel furthest from the master cylinder and then moving progressively closer. Pressure bleeders are the best. Otherwise a one man bleeder attached to the bleed screw and manually depressing the brake pedal - but never further than the normal travel - otherwise you will push the piston seal past the wear ridge in the master cylinder bore, potentially nicking the piston seal, causing a leak which will mean you have to pump the pedal to get it firm during braking. Solution is a master cylinder rebuild or a new or rebuilt master cylinder. (A less I first learned when I was 16 - 48 years ago. )
    BTW the clutch slave cylinder need to be bled in the brake bleeding process too.
