Hi guys thank you for letting me join ,I have owned Audis for years and have just purchased a 95 s2 avant ,it has a slight problem as it is overboosting and cutting the engine ,I am assuming it is a weak spring inside for the waste gate,is this a hard job to do or leave it to the proffesionals ?,many thanks in advance simon
S2 turbo rebuild
Tags: None
Welcome
A weak wastegate spring won't cause over boost. Sounds like fuel cut to me. Have you pulled the fault codes?
First step after doing that is to carry out a full boost leak test.
Imola B6 S4 AvantComment
Ha ha ha , I think I will be ok , it makes a little chattering as it spools up so I might just pull it and check it over anywaysComment
S2 3B and ABY and RS2 ADU Boost Leak Testing
S2 3B and ABY and RS2 ADU Boost Leak Testing:
Click here:http://www.s2forum.com/forum/showthr...t+leak+testing
to S2 ownership
