Happy new year!
I really need to go back to work - being at home twiddling my thumbs leads to expensive ideas!...
In 2013 Error404 asked a question about whether any fourm members had a U/S cleaner and how it performed. The reply included links to an ebay auction item which someone had bought but those links are now too old to work.
I'm very very tempted to get one as it seems to do good stuff...
http://www.ebay.co.uk/itm/1818728238...%3AMEBIDX%3AIT
I found this on Ebay from a company local to me and have the same question really - does anyone use this sort of entry level of cleaner and how do they find it? Only drawback is that annoyingly it is about 3-4cm short of being able to get a 5 cylinder head into it in one go.
I've been trawling through info on the net and see that 25khz is the best frequency for aggressive cleaning and 40-45khz is softer (but slower) and is better for acting in blind holes,passages, round corners etc. The link shows a 40khz set up and does include heating which is essential for the formation of the cavitation bubbles.
I fully appreciate that you get what you pay for but weighing up the costs of running a U/S cleaner with a bottle of concentrate solution against paying someone to vapour / soda / grit blast / hot tank dip / solvent parts washer etc I think there may be something in it... I think i'd be a lot more inclined to clean things if i could do them at home rather than driving off to wherever and waiting to drive back again before handing over some money! Earlier this evening i had been contemplating using my pressure washer with a siphon feed or pressure pot supplying glass beads to the flow of water - kind of DIY vapour blaster. I think it would work but without being able to recover the glass beads it costs circa £20 for 5kg tub and the cheapest pressure pot at the mo is £54. My pressure washer is more powerful than my compressor so offers more promise than DIY dry blasting with just air which is likely to be dissappointing not to mention REALLY REALLY messy.
The kind of dirt i am hoping the above machine will clean is:
grease
oil stains
aluminium surface corrosion (the white powdery stuff on the side of my cylinder head)
rust
carbon deposits
grease
oil stains
rust
carbon deposits
