Oil light
  • DEREKCO
    • Feb 2009
    • 435
    Oil light
    After sorting the no boost issues another issue has arisen oil light flash,s when engine revs over 2000 what should I look for switch,s or connector stn 2 plugs?
  • hunker7
    • Mar 2014
    • 3487
    I had this problem when I put engine back in mine, check if connectors are on properly, wiring etc. If that's all good probably sensor is dead.
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    • quattro-nick
      • Sep 2012
      • 1746
      • Country: Belgium
      first i woud measure the oil pressure with a mechanical meter to be sure
      TWINCHARGED power,zero lag
      AEM W/M injection
        AAN Oil Pressure Sender, Switches, Wiring and Check Valves
        There are two oil pressure switches, F1 and F22. There is a hand-over from F1 to F22 (or F22 to F1) in the Autocheck warning system at around 2000 RPM. So as Hunker7 suggests check your wiring to these two switches.
        AAN (and ABY and ADU) Oil Pressure Sender, Switches, Wiring and Check Valves:
