So finally got round to doing the steering rack and heater matrix on a cab I am doing up, been putting it off for a while as they are both nightmare jobs. I have the matrix out and am looking to replace the foam, have read a few of the write ups on this and looks like people have had problems with different types of foam. Has anyone found sonething that works long term?
Heater matrix foam
Here is a small write up I did.
quattroworld.com Forums: When doing your heater core, you should also re-cover your heater box flapsThe Audi Enthusiast website. Forums for all Audis including A4, S4, A5, S5, A6, S6, allroad, A8, S8, TT, R8, Q5, Q7, 4000, 100, 200, v6, v8, vintage, local forums
This is the material I have used in about 8 different boxes.
It was to redo the flaps, now all done, just waiting for floor to dry out before putting in a replacement floor carpet then it's going back in. Used some stuff I found on ebay called max tape, appears to be the same type of tape as Arma flex but only a tenner for 30 ft which is enough to do at least 3 or 4 matrix, will see how it holds but looks good quality with strong adhesive.Comment
