Good morning,
I have had a (mans) look through the forum I can't seem to find the answer
I have a question regarding the front brakes on my RS2 the car as far as i am aware had the standard front disc's when I started the refurbishment, I have come to put some bigger disc's on the front which are 322mm but the callipers don't fit the calliper carriers
there is a gap between the calliper and the calliper carriers.
Do I need new calliper carrier's or new callipers? or would it just be better to get new drilled and vented 304mm disc's?
Your help and views are welcome thanks in advance
John
there is a gap between the calliper and the calliper carriers.Do I need new calliper carrier's or new callipers? or would it just be better to get new drilled and vented 304mm disc's?
John
