Audi s2 3B to coil pack conversion HELP
  • smh
    • Jul 2008
    • 70
    What things do I need for SURE to be able to convert from a distributor to the coil pack .
  • SteveH
    • 4460
    TFSI coils and a suitable loom (speak to Error404), ABY/ADU or AAN ECU and the pin swap on the ECU connector. You can keep the 3B dizzy and its hall sensor as the trigger. Hardest part is the ECU pin swap as it's a pain to do in the footwell.
    You will then need to consider what map the ECU has and your fuel pressure reg. The 3B fuel reg can be changed to a 4Bar unit from a 20v 7A engine and it's a direct fit.
    91 Modded 3B
    14 A6 Avant Black Edition
      You need an ABY ECU and the various pin-outs documented here:
      Then you need a TFSI loom to replace the equivalent ABY POSs and coils.
        Thanks Steve,
        Yes I can help you out with a 3B conversion harness kit if required :
