Can anyone help with torques on bolts on hot and cold side of turbo ? The 4 T30 bolts that hold the plate to the centre housing and the 6 on the exhaust side cheers .
K24 7200 torques
Tags: None
Thanks but need torques for actual turbo bolts , I've had it apart to refurb ?Comment
So refurbed the 7200 new bearings n 360 thrust bearing, tbh if I'd known how good nick it was in internally I wouldn't have opened it up, but then I wouldn't have found the small crack in the turbine housing
. anyone got one about they're be up for selling ?
Also would the stock 7000 turbine have ousing fit the 7200 ? Just a thought ...
Anyway turbo in turbo technics for balancing ...
Oh, and the shaft is shagged ,
good job I got the turbo pretty cheap !!
