Just sorting out my sump setup. Running a 7A sump with one of Thuppus baffles and a IE girdle. Should I use a AAN windage tray as well. I think yes as the windage tray and girdle are performing different duties in regards to oiling. But it also seems like it might be a little congested down there and will also have to run 3 sump gaskets.
You can't use a gasket between the girdle and block, only a really thin layer of sealant.
The idea is to use the orginal windage tray with the baffle, but I hav't check how it looks with a girdle. It shouldn't be a problem regarding oiling. I was going to use them all in my strocker build...
