Timing job, with 3256 tool ?!
  • Gazmitchell
    • Feb 2013
    • 640
    Hi all , quick one I'm doing cambelt on my ABY and bought the gen audi tool 3256 but can't suss it for the life of me , I know it's a tool only to loosen crank bolt and not hold it at TDC, but I can't see where the bolt screws into ? I'm turning the tool and crank and it's arch only lines up with one of the stub mount holes, but the tool is too short and sits at least 2 inches off of the block ???? can someone point me in the right direction.
  • twoqu
    • Sep 2003
    • 3103
    The 3256 is not the right tool. Read through this for suggestions to make it nearly right!
    • Gazmitchell
      • Feb 2013
      • 640
      Cheers, thought there was too many pulleys on bottom crank, making it too deep on an ABY ...as all pics I can find are AAN , sheesh , so longer bolt and spacers.
        You CAN use the 3256 on the ABY motor with a little addition from the toolbox - I did it on mine some months back when unlocking the bottom before I lifted out the engine.
        I need to find a photo.
          Here goes - use the snub mount with the rubber removed and a sturdy deep socket placed over it to create a counter-hold. I actually had a 3/8 extension through the hole of the snub mount as well to fill the void. Another tip, not shown, is a large G-clamp to keep the 3256 tool nicely in place on the pulley while you are schwinging on the bar.
          • Gazmitchell
            • Feb 2013
            • 640
            Cheers Paul think I've sussed it , all bolted up with support on threaded bolt , just need a big 1/2 drive socket now as I've snapped my extension with the scaffold pole attached 😖
            Another note the ECU and TCAs are on the way to you ..
              Top tip - go for a 3/4" socket and schwing bar - there is monster torque involved and you will damage all but the very finest quality 1/2" tools.
              Good stuff on the ECU etc
              • Gazmitchell
                • Feb 2013
                • 640
                Yep think I need HGV size kit for the crank bolt .
                  Its a small investment that makes the job *SO* much easier !
