RS2 Engine Torque Settings
  • johnboy 3169
    • Nov 2009
    • 300
    Could do with some help.
    A friend of mine is rebuilding my RS2 engine and he is looking for all the nut and bolt torque settings for the engine does any one out there have them please also can any one recommend a place to get (good quality) piston rings from.
    Thanks for your help in advance
    John
  • Mikes2
    • 1704
    Same settings as for the AAN / ABY
    Mike
    http://www.s2-audi.co.uk
      Originally posted by johnboy 3169
      Could do with some help. A friend of mine is rebuilding my RS2 engine and he is looking for all the nut and bolt torque settings for the engine
      ADU --> ABY--> AAN:
      • gvr
        • Dec 2007
        • 43
        • Country: South Africa
        Hi Johnboy
        Pistons and rings are the same as a VW 1600 Golf motor, can get them at VW dealer.
          If you go here: http://audi.7zap.com/en/rdw/audi+80+.../107-107000/#3
          The 81mm diameter rings seem to cross to a number of VW and Audi products (shown when you click on the [(i)] icon.
          However, when you select #1 and do the same for the 81 mm diameter piston, there are no crosses to any VWs.
          Just sayin'
