cctv view on phone help
  • Rikki Kitto
    • Feb 2010
    • 6276
    Any cctv bods out there help me with connecting my system to my BT hub so I can view on my phone? Since fitting the new hub from BT it no longer works
  • Typ89
    • Apr 2015
    • 119
    I probably can. So what's your question?
    • Rikki Kitto
      • Feb 2010
      • 6276
      need to change the hub address or port forwarding or something as the new hub is different to the old one. the system works fine but can no longer view the cams on the phone app
      • irishs2
        • Apr 2009
        • 2455
        you need the ip address of the camera dvr and the ports that it uses. If you have a mouse attached to the dvr, you can log in and go to the network settings and it should tell you what the ip address of it is. Or you can log into your old router temporarily and see what NAT rules have been setup.
        Then on the bt router, you need to login to that, go to NAT settings, and create rules for any ips on the outside, on the port your dvr uses (there may be more than one) to the ip of the dvr.
        Eric
        95 S2 Avant under rebuild.
        • Rikki Kitto
          • Feb 2010
          • 6276
          Cheers but I'm no wiser, do these pics help
          • Rikki Kitto
            • Feb 2010
            • 6276
            Do these pics help
            • Rikki Kitto
              • Feb 2010
              • 6276
              No idea why they are upside down and side ways but hope they can help
              • Typ89
                • Apr 2015
                • 119
                I'll try to keep it simple.
                Normally all outside access to your home network is blocked by the firewall in the router/hub. Good thing if you don't want nigerians stealing your data, not so much if you're trying to access your cctv.
                So you set up a virtual port in the router, by which you'll have access through the firewall to the device with the corresponding port number(s). In this case 34567 and 1111. Set these in the router and it should be working again. Can't help you with the port forwarding setup, that's router specific. Maybe Google knows
                  You will likely need to reconfigure a dynamic DNS service so that you can locate your cctv camera when the IP address for your house changes. It is in the advanced settings to add one of these services. Once added you should be able to access from that service
                  • Rikki Kitto
                    • Feb 2010
                    • 6276
                    Cheers guys I'll have another go when I get home, it's a bit like trying to follow instructions in a foreign language though abs I am not too sharp when it come so to computer issues😳
                    • irishs2
                      • Apr 2009
                      • 2455
                      Found this PDF which should guide you though the process of adding forwarding ports. on the bt hub 5.
                      You will need to use your information though.
                      IP of the CCTV :192.168.1.177
                      TCP Ports to forward: 34567, 1111
                      Eric
                      • Rikki Kitto
                        • Feb 2010
                        • 6276
                        Well been fiddling about for a few hours and still no joy, looks like I'll have to shell out for a bod to pop round and sort it oot, thanks for trying fellas looks like computers just ain't my friend
