This is just a general observation rather than S2 specific, but so far this year we've changed 1 headlight bulb on the Ur quattro, 1 on the S2 and 2 on the Land Rover. On the trip to Wales we blew another on on the Land Rover. We now carry spares, so a quick swap sorted the issue...
Now I know what you are thinking, cheap '*****' Halford specials, but no... We've only ever fitted the best
Bosch or Philips options...
Is anyone else suffering from 'p|ss poor' headlight Bulbs or are the special 'crap' ones all saved up for me? Surely they've got to be good for more than 1500 miles or 6 month's worth of driving?
Yours, in the dark...
Ian
Ian
), and he said that if you were able to reduce the voltage available to your house, then by doing so by only 5%, would roughly double the life of the lamps because they were being manufactured to produce the absolute maximum amount of lumens for the rated voltage.(To the point that if you lived in a small village close to it's sub-station, then you probably would change lamps far more often than those in a property on the outskirts, who maybe would suffer a slight voltage drop to their premises. The allowable voltage drop is from memory 6v (2.5%) on a single phase installation, and this could make a real difference to lamp longevity) Obviously the hotter a filament lamp burns- the greater the light output, up to the point of melting the filament. With the tight tolerances that these things run at (and is a 12v car lamp any different in principle?), even if the alternator regulator voltage on your vehicle was only a few percent above where it should be could potentially decimate the lamp's life.
