Mounts , engine and gearbox
  • Gazmitchell
    • Feb 2013
    • 640
    So the mounts look fine, engine and gearbox , but as they're orig I bet would you replace as a matter of course.. , ? No splits or rubbing pressure marks, but guess they'll degrade ?
  • SteveH
    • 4460
    Gearbox mounts seem to last forever. Engine mounts take a beating and often look ok until you take them out of the car and realise they are in two bits!
    91 Modded 3B
    14 A6 Avant Black Edition
    • Gazmitchell
      • Feb 2013
      • 640
      Hmm wonder if the engine ones have been changed then as they look absolutely fine...
      • Siim89
        • May 2016
        • 14
        Usually the one on the passenger side on LHD cars fails as the engine rotates like it wants to pull that mount up and pressure the other 1 down.
        Mine was also looking fine but after taking it off it was almost falling in 2 pieces.
        I have polyurethane mounts now and everything is much better. Slight rattle on the idle but nothing worth mentioning.
        • s2dk
          • Jul 2016
          • 507
          • Country: Denmark
          if doing gearbox then do some from a b5 s4 or a allroad /2.8v6 tip they fit with a minor makeover
          • s2dk
            • Jul 2016
            • 507
            • Country: Denmark
            in a b4 that is
            • Rusty
              • 18953
              If you take them out and inspect then you'll be able to see date marks and give them a proper look over. If they're not broke then maybe not worth replacing, unless you're going to do lots of track days or fit a HUGE turbo...
              • hunker7
                • Mar 2014
                • 3487
                When I replaced engine mounts they looked fine till I took them off, if they're not split they'll be sagging. Old ones were about 0.5-1cm lower than new ones.
                '93 Audi UrS4 Avant
                '15 Audi A7 quattro 3.0 TDI
                • Gazmitchell
                  • Feb 2013
                  • 640
                  Gearbox mounts are shagged .. engine mounts seem ok , dropped gearbox and subframe down as one , and also the gear linkage gaitor is shot too.
                  • Gazmitchell
                    • Feb 2013
                    • 640
                    Ok so do need to change the engine mounts also, one is marked and sagging as you'd said... Not in two but there movemont on the stud.... so oe ones from AT an eye watering 100 euros plus each , wondered if any one has used the " Genuine Febi " ones on ebay lol. . Only doing the rs2 conversion so not tracking or mahoosive thrust! But want em to last so I don't have to change em again hopefully !
                    • hunker7
                      • Mar 2014
                      • 3487
                      I have Febi on mine for a year now and still going strong.
                      '93 Audi UrS4 Avant
                        Genuine Febi is still genuine crap
                        If you want them to last, get OEM. 20 years & 150k miles is hard to beat on value for money
                        • Gazmitchell
                          • Feb 2013
                          • 640
                          I agree , just wondered how good the " genuine copies " actually were.. I've gone OE on all other bits like subframe bushes , and door seals at around £500 for two !!?? 😳😖so these are a bargain !!😣
