help finding this plug
  • david1980
    • May 2014
    • 1025
    Does anyone remember seeing this plug of this style on either a cab, 80 or a4 b5?
    I need another one but can't remember what location or model they came fitted to and vaguely remember seeing one on the stereo in my old avant
  • nip
    • Apr 2006
    • 1786
    • Home: United Kingdom Current: Abu Dhabi
    Is it for the vdo clocks or something in the region, for some reason that's plug is familiar
    • david1980
      • May 2014
      • 1025
      I think there might be one there? It also reminds me of the speaker plugs for the rear speakers for the avant
      • Mikes2
        • 1704
        Looks like the connector for the outside temp display. How many pins are there ?
        Mike
        http://www.s2-audi.co.uk
        • YELL MAN
          • Dec 2005
          • 535
          • Country: Shetland Islands
          Don't think it is the temp display as it is Yellow and has more wires coming from it.
          1994 Indigo Blue S2 coupe
          1994 80 Avant 1.9 TDI
          2005 Yamaha Fazer 1000
          1953 AJS Model 18S
          • K Simmonds
            • Dec 2007
            • 7627
            Where about's is that two wire one located? There are a couple of unused connectors in among the mess of wires under the fuse box.
            There's a connector like that behind the clocks on some models only with four wires going to it, I have no idea what it's for as the outside temp connector is yellow and Audi do tend to colour code their electrics. I used it to connect the outside temp display and am soon to do the same on my B3 quattro, can't remember exactly what I did but it involved some cutting of wires and splicing into others as well as adding a twin core cable to sensor itself. I followed a guide on here but it was nearly ten years ago so I can't find the thread
            1990 B3 2.0 80 quattro.
            1992 C4 2.8 Avant quattro
            1994 MTM RS2.
            1998 B5 TDI quattro Sport.
            2000 B5 TQS.
            • david1980
              • May 2014
              • 1025
              The plug I have is on a loom from a vw. I was just after another of these plugs for a project and am still looking for one. part number is: 893 971 634
              I tried looking on etka but for some reason I can't find it
                Originally posted by david1980
                The plug I have is on a loom from a vw. I was just after another of these plugs for a project and am still looking for one. part number is: 893 971 634 I tried looking on etka but for some reason I can't find it
                Do you know about "ATP" and how it works? You start by clicking on the binoculars icon. Select "ATP".
                When I put that PN into ATP (with no spaces, i.e. 893971634) and then selected "All Models", I got 67 hits comprised of C4s,A3s,B5s, RS2s, S6Plus, etc etc. over various years. Very very common. Suggest that you have another look and then drill down. I think there were five locations in a C4 UrS4 for example.
                OR just buy this one: http://www.ebay.co.uk/itm/AUDI-VW-Sk...-/181932094680
                • david1980
                  • May 2014
                  • 1025
                  There must be something wrong with my etka. I have tried doing that and it just comes up with search yielded no results.
                  I need to get hold of a later version and install it on my newer laptop and see if that helps with my search.
                  • domas
                    • Oct 2014
                    • 307
                    • Country: Lithuania
                    first do the search in part number section, see if it was replaced by something, if yes, ATP the new code.
                    • Val
                      • Apr 2008
                      • 630
                      • Country: Latvia
                      Choose your market and model of interest. Can't be easier than that.
                      5vtq gte
                        I was using a 2007 version and ATP worked fine.
                        • Audicted
                          • May 2004
                          • 366
                          • Home: Jamaica Current: United States
                          I believe it is behind the steering wheel when you try to remove the instrument cluster.
                            Originally posted by Val
                            http://www.oemepc.com/tvn_result/search/tvn/893971634
                            That is an excellent resource. Thanks for posting.
                            Otherwise, (with similar end result):
                            Try this:
                            http://audi.7zap.com/en/rdw/audi+100...959-959015/#20
                            Then go down to item 20 and click on the (i) icon. A fantastic list of VWs,Audis,Seats and Skodas that used that flat pin contact comes up.
                            Select one of the vehicles that you have and click on that list and follow the PN down the rabbit hole.
                            • david1980
                              • May 2014
                              • 1025
                              Thank you to everyone who helped, especially urs4boy for the help. I've managed to source a plug now so can get on with what I had planned.
