Help identify a wire
  • maiks
    • Dec 2014
    • 295
    It is located under the dash. Car urs6.
    It was loose and i could not find a place were to put it.
  • M2ki
    • Aug 2015
    • 547
    Trailer operation warning lamp? Where does it come from, 4 pin turn signal relay?
    If so, then it goes the socket with green arrows and number 1
    1989 Audi 80 Quattro
    • rxl
      • 1913
      i think so 2. my rs2 had the same lamp and it wasnt in the dash as it had no hook.
      • tekstil
        • Jun 2011
        • 104
        Where exactly did you find it? Behind cluster or under dash somewhere? When i changed bulbs on my cluster i also found random bulb with socket and wires hanging there. Turned out to be Check Engine light Not sure though if UrS6 has one, mine is UrS4.
        • rxl
          • 1913
          it was behind the cluster but didnt seem right as all the bulbs are placed in the dash direclty...
          • tekstil
            • Jun 2011
            • 104
            Hmm you are talking about RS2, can't comment on that as i have not seen their clusters backside. But in UrS4 the portion where is Airbag light / Check Engine light / ASR aus / some steering wheel icon etc - bulbs are not powered by circuit board, there are individual wires/sockets/bulbs for them, cluster only has notches where you can "click" them in.
            • rxl
              • 1913
              Well we learned from this something
              Gesendet von meinem EVA-L09 mit Tapatalk
              • veneto rs2
                • Jun 2006
                • 1022
                • Country: Veneto
                For the italian market only there's a lamp like that for the side lights.
                It's the one between the battery and the parking brake.
                It switches on when you switch the lights to the first position.
                http://www.audisportclub.com/
                • maiks
                  • Dec 2014
                  • 295
                  I remember that Trailer operation warning lamp and ASR lamp holes are empty and wire comes from the left side.. It may be trailer operation warning lamp, because I have original trailer hook. I will check after holidays...
                  • maiks
                    • Dec 2014
                    • 295
                    It was trailer operation warning lamp.. How do I know? I remember that my old vw's trailer light turned on when emergency lights blinked. So I went to check and it started to blink also when I put emergency lights on. So I am 100% convinced that it is trailer operating lamp.
                    • M2ki
                      • Aug 2015
                      • 547
                      My car had an aftermarket trailer hitch retrofitted and the turn signal relay was replaced with this hella relay, where the 4th pin is trailer operation warning lamp ouput, other lead from the lamp was screwed onto the chassis ground.
