LED security lights
  • Rikki Kitto
    • Feb 2010
    • 6276
    LED security lights
    Any wiz kids on here know how to fix the new type LED security lights I've had three out of five go wrong in the last year thought they were suppose to be the nuts, low cost last for ages
    They still come on so sensor is OK and have power but all you get is a very dim flickering LED
  • HPsauce
    • Sep 2015
    • 227
    Is this a whole unit wired to the mains or just a replacement LED bulb?
    If the latter then LED versions can often flicker dimly when the main circuit is nominally "off" due to residual current leakage in the electronic switch.
    With an old-school filament bulb you still get this but it doesn't warm up enough to be visible.
    • Rikki Kitto
      • Feb 2010
      • 6276
      Whole unit and have two wired to different locations so power source is not at fault as have halogen type lights running from same place, very frustrating as I didn't keep receipts
      • AndyP
        • 6049
        Try ordering a new LED unit and solder it in
        http://www.ebay.co.uk/itm/10W-50W-10...INlrHzNg1TNxIg
        • Rikki Kitto
          • Feb 2010
          • 6276
          Worth a try before I chuck it thanks
