Isn't it nice when you get through a few small niggles and everything is back working how it should?
I had some issues with Samco hoses losing integrity - either splitting or just getting very soft. This resulted in significant coolant loss a couple of times (fortunately I always carry spare water and was lucky each time)
Changed the old Samco hoses to Roose hoses... while I was at it I wanted to get the temp gauge reading more accurately and also get both speeds of the rad fan working when it should...
So... changed hoses, bled and road test. Coolant weep from bleed screw on matrix hose. Remove screw, check o-ring, no issues... wtf? Turns out the bleed fitting was apparently not glued in properly and it was weeping up the side of the fitting, not through the bleed screw.
Phone call to Roose... very helpful, new hose arrived in Belgium in 2 days... bleed fitting fitted really well in a slightly longer tail - as per my suggestion, a clamp round the fitting... belt and braces... apart from the hassle I can't fault how they resolved my issue.
Fit and test... no more leaks... yay...
New Behr MFTS, new Bosch ECU temp sender and a new Behr rad fan switch later... temps look right... fan comes on and off as it should... boost is at the correct level (also linked to an N75 issue)
Happy days...
Here's a pic of my new hose with the clamp. Much better idea IMHO...
Happy days...
