Help with ABS Problem..
  • kninio
    • Aug 2004
    • 641
    • Home: Lebanon Current: United States
    Hi , yesturday i`ve been driving the car for 100 km distance and once i tried to break.. the pedal acted as it stuck and when i forced to press it the car pulled at one side as just the right front wheel has breaked , then i repress it and it works ok , then in the night it acted the same and i pressed it hard then truely it was just the right side wheel is realy blocking and it was dangerous because it was about to cycle the car on me , any way any body know why the ABS Is behaving this way with me? what can be the fault? i just changed the front ruber boots , and after it the abs has light on and i return the car to the garage and they fix it they said it was the sensor pulled a bit , but i wonder why now its like that working?
