Strange
  • rotoryboy
    • May 2004
    • 3281
    Strange
    Well had a strange thing happen yesterday. Took the car to my VAG specialist, who looks after my car, to get the handbrake cables replaced. He rang me up to say they had trouble getting the car started (with the key) but they managed. The only problem now is that now its running, they turned the key off and removed it from the car, yet it still runs . He stalled it but the ignition stays on.
    I went up and dismantled it thinking it would be the plastic module on the back of the ignition barrel (I recall someone on here with that fault). Pulled it all apart to find that the bar in the barrel itself, that locates into the plastic module, had snapped clean off . Anyone else seen this before??
    Mark
    Race Clio RS197
    S2 Coupe ABY (Green) - RIP
    S2 Coupe ABY (Blue) - Sold
  • Keeper of The Kitten
    • Dec 2003
    • 2317
    Wait a minute - are you saying that the metal bit has broken?!!
    I've had the plastic bit fail on two different cars - but this looks strange.
    __MDC__
    Martin Cutting
    • rotoryboy
      • May 2004
      • 3281
      __MDC__
      Yes, thats what confused me. The plastic is fine yet the metal bit snapped
      Mark
      Race Clio RS197
      • slow2
        • Apr 2004
        • 238
        yes this is very common amongst 80,100,early a4,(1987-96) had this a few times,
        when replacing be sure to take the barrel and cylinder to check and compare with
        replacement, as there are a couple of types with slight differences in length and
        location point
        Dez
        Never did overtime until i purchased........s2
        • slow2
          • Apr 2004
          • 238
          I think the return sping in the plastic ignition switch is too strong for the job it dose and puts all the strain on that small aluminum peg, then over years aluminum get
          brittle
          Dez
          • SteveH
            • 4460
            I had this happen on MY91 3B. The metal peg broke off but the car wouldn't start. Happened on the day we were going on holiday to France with the car Just glad it snapped before we set off. Quick trip to All Audi sorted it
            91 Modded 3B
            14 A6 Avant Black Edition
            • HPmuirt
              S2Forum April Fool
              • Apr 2005
              • 3014
              I too had a problem with the ignition of my 2.8 Coupe, which was the white plastic part, but heard from my Audi specialist friend that the pins can break.
              It occured to me at the time that whilst mine was apart, I should see if I could get one made in SS, but my mate fixed it before I could get back to the garage to take a look (damn hard life having a best mate who was VAG trained and owns a garage
              Anyone on here know if it would be easy to do?
              Cheers n
              Si
              Subtle mods here and there
              2011 A5 3.0 TDi - Lava Grey
                Yes I've heard of this quite a lot actually - its NOT unusual as they say !
                • ~Delta
                  • Apr 2005
                  • 797
                  Quite common for the peg to snap, there is an improved version from VAG now, it's slightly thicker, more D - shaped. Make sure you purchase the right one.
                  Never show a fool a half built house.
                  Never underestimate the power of stupid people in large groups.
                  Life is like a **** sandwich
                  The more bread you have, the less **** you eat
