Distilled water - good or bad?
  • Skull
    • 3506
    • Country: Slovenia
    Hello!
    I heard many people saying that distilled water in the cooling line is bad, that it corrodes the radiator and stuf... it is for real or they are full of s...?
    Audi Quattro WR
  • Jas11n
    • 5067
    Any water on it's own will corrode and mess you water system up. Distilled has no limescale in it, and mixing with a good VAG antifreeze (G12+) is about the best you can do. I've used distilled water in cooling system for 10+ years with no problems.
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
    • dan_b
      • Sep 2003
      • 3670
      Fourrings is exactly right - you ideally would want to use the correct mixture of distilled water and Audi coolant. UK tap water is fine with Audi coolant as well in all honesty though. Any type of water just on its own is bad in the long-run.
      The thing to avoid putting in the coolant system is "Mineral Water" - stuff like Evian, as well as being a very expensive source of water, it contains lots of dissolved mineral deposits which will end up deposited on the inside of your cooling system.
      • kninio
        • Aug 2004
        • 641
        • Home: Lebanon Current: United States
        so what do u advice? i use the water which i buy for drink from NESTLE. or distilled water? in both case i will mix it with the G12 PLUS
        any advices
        • kninio
          • Aug 2004
          • 641
          I Check the bottle of water they write at it , it include some calcium so its not calcium free so? is it suitable?
          • redcar
            • Jan 2005
            • 134
            check this web site out WWW.freshlysqueezedwater.org.uk
            cheers Nick
            • redcar
              • Jan 2005
              • 134
              i have taste the water at a show here in the midlands. and you know what, it tastes really great. when you look at it the water is very clear. they gave me a dvd to watch. i will see if i can post it on the forum.
              cheers nick
              0-60 in 2.3 sec
              • Keeper of The Kitten
                • Dec 2003
                • 2317
                Originally posted by redcar
                0-60 in 2.3 sec
                Do tell!
                __MDC__
                Martin Cutting
