Girlfriend Cheats. Apologises. Boyfriend Replies
  • HPmuirt
    S2Forum April Fool
    • Apr 2005
    • 3014
    Originally posted by Jamo
    If it took 45 mins she must be cr*p at giving BJ's
    Depends on how many she had lined up
    Cheers n
    Si
    Subtle mods here and there
    2011 A5 3.0 TDi - Lava Grey
    • WabTheKing
      • May 2004
      • 2567
      yeah your girlfriends sub 5 :mischeif:
        I don't fancy not being able to walk for a week due to friction burns
        • WabTheKing
          • May 2004
          • 2567
          dont walk on your 3rd leg then
          • mreinders
            • 72
            • Home: United Kingdom Current: Netherlands
            #20
            One fine day mister rabbit goes running around the forest and he sees a giraffe rolling a big fat juicy joint and says "giraffe giraffe! why do you smoke puff? come run with me and get fit instead" so the giraffe stops rolling his reefer and runs with the rabbit . Then they come across an elephant doing big fat lines of charlie on a mirror . The rabbit says "elephant elephant. why do you do drugs? come run with us instead and get fit ." so the elephant stops and goes running with the two then they come across a lion preparing a syringe of smack "lion lion" cries the rabbit, "why do you do drugs? come run with us instead." The lion with a mighty roar squashes the little rabbit to smithereens. "no!" the giraffe and the elephant cry "why did you do that? all he was trying to do was to help you out!" The Lion says "Fecking rabbit always makes me run around this ****y forest when he's done a few pills."
            010100110011001000101111010000010100001001011001
            011000100011010101010011001101000100000101110110
