k26/27 hybrid turbo
  • volcano rs
    • Jun 2005
    • 2265
    k26/27 hybrid turbo
    got some info from turbo dynamics for those of you that know your turbo's
    exhaust side is 64ar
    compressor is secret
    they got 404 bhp and 485lb of torque but they said more is achievable depending on who maps it .
    part number on turbo is md14.7 is there any other number i need to ask them so i know what exact turbo i have?.
    You aren't the only one with one of these... I'm sure I've seen reference to the MD147 name before. Maybe with one of the guys down under running with a conversion kit he imported from the UK.
    I strongly suspect that Mihnea will know the internals. He can map that sucker (sorry blower) as you like...
    400bhp is about the normal limit for a K26/27 hybrid - tis confusing though cos of the various differences in turbines and compressors. Makes me wonder if any two K26/27 hybrids in the world are actually the same ;-)
    • volcano rs
      • Jun 2005
      • 2265
      so you recon thats about the limit of that turbo ? or do you think more can be had ?
        I'm sure Greg knows something about that turbo
        • Mihnea
          • 1288
          No way that turbo can EVER do 400 BHP, not even in KKK's top engineer's sweetest dreams. A few of those that I have mapped do around 320-330 BHP, another one did 360 and that's the highest I've ever seen out of that turbo.
          Regardless, I'm still open to see if ONE turbo will do 400 as every car is different, but I'm not holding my breath....
          HTH,
          Mihnea
          www.MRCTuning.com
          info@MRCTuning.com
          Workshop Directions
          • volcano rs
            • Jun 2005
            • 2265
            its bigger than rs2's is it not ? and if so can you get that out of an rs2 ?
            • Mihnea
              • 1288
              The cold side is marginally larger (27 based compressor wheel, RS2 is 26), the hot side isn't as good as the turbine wheel is back cut...
              an RS2 with a decent cat-less exhaust can do around 370-375HP.
              www.MRCTuning.com
              info@MRCTuning.com
              Workshop Directions
              • volcano rs
                • Jun 2005
                • 2265
                what are you basing that on ? what mods along with that turbo ?
                • Mihnea
                  • 1288
                  Full turbo back exhaust, intake mods, blah blah blah blah and hours spent mapping...
                  www.MRCTuning.com
                  info@MRCTuning.com
                  Workshop Directions
                  • volcano rs
                    • Jun 2005
                    • 2265
                    its hard to believe its that bad . best to have a rs2 turbo then .
                    • Mihnea
                      • 1288
                      Honestly, YES. Now if you want real 400 HP without headaches, the same turbo as Doug's or Tom's will do a great job, with a good potential of 440-450 HP maybe more on a tubular exhaust manifold....
                      www.MRCTuning.com
                      info@MRCTuning.com
                      Workshop Directions
                      • volcano rs
                        • Jun 2005
                        • 2265
                        is it still based on k26/27 ?
                        • Mihnea
                          • 1288
                          yup same EM/DP fit...
                          www.MRCTuning.com
                          info@MRCTuning.com
                          Workshop Directions
                          • volcano rs
                            • Jun 2005
                            • 2265
                            so they would rebuild mine or a new unit altogether?
                              There does seem to be a bit more top end with the MD147 compared to RS2 turbo on engines with similar setups
