i wanted to clean my maf is intake cleaner/carb cleaner good or use something else?
cleaning maf 7a
Tags: None
I would recommend buying 1 litre of Isopropyl Alcohol (IPA) - get it from your local chemist (they may have to order it for you), put the IPA in a container in a well-ventilated area and simply put the entire MAF assembly in the IPA and leave to soak overnight. Et voila, one very clean MAF, leaving a lot of rather murky-looking IPA.Ex S2 owner, now running around in an A4 Avant quattro...
