Has anyone found a good way to clean out their water system. In the past someone has mixed the dreaded 2 fluids to create that lovely brown, rusty mess everywhere. I know the res tank will be stained for good now but want the system clean before I replace it. Any BTDT's or Recommends?
water system flush
Probably best off with a hose. I did mine by removing the top hose, thermostat and a heater hose (or both). Flushing and back-flushing through the block and heater matrix (and rad) until clear water has flowed through for a few mins.
Carefull use of a pressure washer can be effective at flushing the system too, though best off with the hose really.
You could try refilling the system with water alone, running it for a couple of minutes or so before draining it and replacing it with the proper coolant mix.
If you want to use a rad flush product then make sure its a liquid one and not a granule based product. I spent ages getting it the little bits out of the system!
And if you didn't consider it already use some nice De-Ionised/Distilled water with your G12+. (halfords amoungst others sell it).
My local Tescos sells it too.Originally posted by PeteRRAnd if you didn't consider it already use some nice De-Ionised/Distilled water with your G12+. (halfords amoungst others sell it).
Apparantly some people use it in steam irons, whatever they are.
David1994 16v Coupe - Sold on and sadly missed
1994 S2 Avant - Warmed up a bit
1995 A6 Avant - Dag Dag DelightComment
