Stripping down the transmission?
  • ctolladay
    • Apr 2005
    • 292
    The S2 is making a noise. It's a whine that increases with speed. I therefore think it's after the gearbox (or on the output side of the gearbox). It's about time I sorted it but I can't afford to get it done by a garage.
    Should I attepmt this or save up and get it sorted by a pro?
    It's also my thought that as so much power is lost in a 4WD system that by sorting and lubing it I might get some power back. What are peoples thoughts? Has anyone tested this out using a RR?
    Please help and advise as I haven't been under the Audi yet (been under a fair few other motors before though, thankfully they weren't moving).
  • AUDI9020V
    • 653
    i could be wrong about it but is that ya thrust bearings that are gone or on there way out.
    1990 100 2.2 10vqt 82k miles(now dead)
    1990 90 2.3 20v 166k miles
    1988 90 2.0 10v 181k miles
    oh and a polo for work.
    • ctolladay
      • Apr 2005
      • 292
      I'm not sure. Is there any way of telling without stripping things down?
      • AUDI9020V
        • 653
        some of the guys on here will tell you wot to look out for
        • ctolladay
          • Apr 2005
          • 292
          It has been recomended that I change the diff and gb oils first to see what effect this has. What's the recomended stuff? Where can I get it from with out having to give up a kidney? Please help!
          • ctolladay
            • Apr 2005
            • 292
            Is the local stealer te best place to get the oil from or can i get it from a motor factors (need to know the details to do this, please help)?
            • Chris5044
              • Feb 2005
              • 1663
              try halfords ... they have gearbox and diff oils
                You can get it from most motor factors, when you change it make sure you undo the fill bung first since that is the one that usually sticks. Once you get that out you can drain it and refill otherwise your stuffed for filling it back up again!
                If you are at the garage meet you could do it there.
