I keep geting this code regarding lambda sensor i have tested the sensor and its switching when you rev it between lean and rich ? my car is de catted don't know if that makes a difference?
2342
Oxygen sensor
- Emissions not within specs
- oxygen sensor goes open loop Oxygen sensor has open or short circuit
Check oxygen sensor and wiring
I would say dodgy wiring, i've never seen O2 sensors give ecu errors they just run too rich and the car dosent go right. De-Cat dosent make any difference, the sensor is before the cat.
91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express
