EEprom Burning
  • Billman
    • 4129
    EEprom Burning
    Hi, i have an Opel C20XE Eeprom file and i would like to see how it behaves! Can someone please burn it for me? How much does something like it costs? is there any Occupation that works with these stuff so i can go there to have it done?
    Thanks
    Go Holset or Go RS4
  • BRY
    • 3755
    Do you know the type of chip you require it burnt onto?
    • Billman
      • 4129
      no, i have only found a file!
      The ECU is a Bosch motronic 2.5
      Go Holset or Go RS4
      • BRY
        • 3755
        I can burn chips, depending upon the type of chip. If you can let me know the type of chip I'll see if my burner can do it.
        • Billman
          • 4129
          the ACU numbers are Bosch: 0 261 200 191 and Opel: 90324334
          Go Holset or Go RS4
          • Billman
            • 4129
            If i send you the files can you find something out?
            Go Holset or Go RS4
            • BRY
              • 3755
              I need the numbers off the chip you want to replace.
              • Billman
                • 4129
                OK, i must check this! I think it will take a while because the ECU is in Greece right now and i am in Germany!
                Thanks for your Replys
                Go Holset or Go RS4
                • s2dude
                  • Nov 2005
                  • 1631
                  The Eprom is a
                  27c256 eprom
                  Most modern burners will do it no problem as it is a common type.
                  hth
                  • SteveH
                    • 4460
                    Same chip is used in the 3B S2 Motronic, cheap and easy to burn
                    91 Modded 3B
                    14 A6 Avant Black Edition
                    • AndyP
                      • 6049
                      Where did you get the file from?? Do you know it is a reliable source??
                      I'm only asking becasue there are some really dodgy eprom files available from E-Bay
                      • Billman
                        • 4129
                        I found the file on a Share Proggie! Dont know if its good? Any sources for good free files??
                        Go Holset or Go RS4
                        • s2dude
                          • Nov 2005
                          • 1631
                          Oh dear. if I was you I would chuck it into the recycle bin (if you use Windows) where it belongs.
                          Not worth blowing your engine for the sake of a dodgy chip...
                          Most likely it won't even be off an S2
