This is a crazy VAG Motor!!
It's the vespa at the end that's truly fightening!85 WR Urquattro, 85 20vT International liveried RallyRep
93 MTMS2 Avant
WTF, with that engine running it will suck the loose change out of the ashtray
, and as for putting a rose in the rose holder???
Shut the roof and windows and it will implode with vacuum. Where do you get them engines from, i aint seen out like that at my local scrappy, and i would not let my worst enemy ride that scooter.
I think he needs a Girlfriend (Just as expensive), or a usefull hobby (like ours nearly as expensive)Everything should be made as simple as possible, but not simpler.--:Albert EinsteinComment
**** that sitting right next to the inlet if one of those blades decides to let go, its bye bye and good night.
impressive none the less.Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim
& 2 bar! Comment
Nah the blades would go outwards - everyone else would be dead! That's what the blanket is for around the area immediately protruding from the rear bodywork.
That mesh and frame are not much different from other jet dragsters, so not as dangerous as might be thought. I agree with Graham though, it needs a proper intake through the roof or all the way to the front in a large tube, or the windows need to be permanently open, otherwise the vacuum on the inside would prevent the thing from running properly (or the driver would be wearing all the windows).
I also find it extremely hard to believe that it is totally legal - it depends on who is looking I think! I seem to remember Clarkson having a small jet on a bicycle in the UK? But of course that didn't create the huge burner pops!
__MDC__Martin Cutting
It's not better than sex, but it runs it a close second.Comment
NEVER
