Why I hate garages!!
  • AndyP
    • 6049
    I replaced both the track rod ends and the adjusters on my 3B Coupe on Friday so I needed to get the tracking re-set, this is how it went:-
    Garage 1 : Sorry mate, can’t do that car.
    Garage 2 : We don’t do Audi’s here, you’ll have to take it to our other branch, which is on the other side of town.
    Garage 3 : Yes we can do it but not until next Wednsday ( this was Sat am ), we’ll need it for 2 hours and it will be £50 +VAT.
    Garage 4 : Yes we can do it this morning, no need to book it in, we’ll do it whilst you wait, £35 +VAT
    So I turn up at garage 4 about 45min later only to be told I’ll have to book it in for Monday as it takes about 1 ½ hours. About ½ mile down the road from garage 4 is garage 5 , so I call in there on my way home, they can check it now, but he warns me that if it needs adjusting I may have to bring it back as these cars are a nightmare to adjust. I tell him that the adjusters and track rod ends are all new and covered in grease so there should be no problem. I’m sure they put the YTS lad on the job because I had to stand under the car with him and tell him how the adjusters worked, but 15mins later and a slight adjustment of about 1° and the job is done, £23.50.
  • mcandmar
    • Apr 2004
    • 5118
    Know your pain, i had a stand up argument with a guy one day who swore blind you cant adjust the tracking or camber on the rear of the car. Ended up having to show the muppet how to do it The best was "camber dosent matter, no point in adjusting that"
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • dan_b
      • Sep 2003
      • 3670
      A sorry tale, well told!
      • slow2
        • Apr 2004
        • 238
        Had my car tracked the friday before gti, now every time i turn left or press down on the steering wheel my horn blows
        Dez
        Never did overtime until i purchased........s2
        • WabTheKing
          • May 2004
          • 2567
          i had fitted brand new rear track arms, and un ceased the fronts
          tracked up by selecta tyre spot on
          1mile down the road after a few tight bends stearing is very very s.h.i.t.e
          jack up to investigate when i got home (another mile)
          one rear tyre shreaded
          adjuster lock nut left loose
          • Keeper of The Kitten
            • Dec 2003
            • 2317
            Wab that is shocking - if ever there was a case for compensation, this is it!
            __MDC__
            Martin Cutting
              Yes indeed - sounds very familiar - feckin schonky 'quick fit' style garages do my head in. They left lock nuts loose on one side of mine last year. Adjusted the damn thing better by feel than they could with the alignment rig.
              If you want this done right - best take it to a good Audi dealership - they are suitably trained and equipped for a true 4-wheel alignment. Aint cheap tho...
              Paul
              • quattro
                • Dec 2004
                • 768
                True 96 quid aint cheap but its brilliant afterwads and in the long run you save on rubber!
                Probably the longet S2 project in history EVER!
                • Markarina
                  • Mar 2006
                  • 511
                  • Home: United Kingdom Current: Switzerland
                  Guess that makes me lucky, I have a garage local to my office that does 4-wheel tracking, know what a pain in he **** Audi's are to do, but still charge the same as they would for any other car, they charge for the check, and then for adjustment front and adjustment rear, and I've never had any problems with them. I do feel a bit guilty when they spend two hours loosening all the front off on my Audi and still charge the same as the guy in the Ford Ka that they do in 10 minutes
                  • Corey
                    Banned
                    • Sep 2003
                    • 2793
                    I also use my local Audi dealership to perform all my alignments, I always make sure the cars are free'd off for them.
                    I charge what they charge me £75+VAT.
                    As in my mind half the battle is won because they have all the correct specifications and equipment, you just hope they can use it. I have not had a bad car back from them.
                    Corey
                    01636 822288
                    • LHD_Kid
                      • May 2006
                      • 3696
                      Garages...?
                      I asked for a full service at the only Audi stealership in my area (I am in Romania) , including cambelt, etc...
                      To which I was asked, "would you like the oil changed as well?"
                      Suffice to say, I said, no thanks, and no service either....
                      I found a very new small garage, who spent ages working on it, with me holding things and generally sticking my nose in making sure they were doing the right thing...
                      All was perfect, charged me £250, including parts, NSF wheel bearing and anti roll bar link rods.
                      I went back the following day, as they had a new 4 wheel alignment machine... They spent 7 hours, as all bolts were seized, tie rods very very seized (surprse, surprise)
                      Computer printout before and after, correct model, correct alignment, all for...wait for it...
                      £20
                      The one good thing about living in a place like this, labour is cheap...just very hard to find anyone who is willing to either learn about or work on anything except a 1970 Renault 12
                      Anyway, its perfect now, had 2 tyres fitted too (rubber v expensive here), drives like it should...
                      (Oh, and beer is about 20 pence a litre, Vodka around the same...)
                      • iain1067
                        • 984
                        Ah so there are some benefits then, and the renault still ives on in the dacia
                        Iain
                        • volcano rs
                          • Jun 2005
                          • 2265
                          dont turn left or press down and you'll be alright
                          • mreinders
                            • 72
                            • Home: United Kingdom Current: Netherlands
                            I was at the garage with the s4, there was all over the sump, turned out the previous mechanic didn't tighten the sump plug properly... what is it with these people?
                            010100110011001000101111010000010100001001011001
                            011000100011010101010011001101000100000101110110
                            • iain1067
                              • 984
                              Of course none of us ever make mistakes, LOL I try not to.
                              Iain
