Anybody done a timing belt on a TDi?
  • mcandmar
    • Apr 2004
    • 5118
    A6 TDi 130ps, is it a straight forward affair or should i run away
    Cheers,
    Mark.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
  • AUDI COUPE 20V
    • Nov 2005
    • 251
    they are not to bad to do front off job raditor and a/c condensor and both fans off and you can access it quite easily throgh there then , bumper bolts can be accessed by lifting the arch liners three 10mm each side
    • philip walker
      • Jul 2005
      • 254
      Asuming the car is 98on
      As above fairly straight forward.
      Use the service pins to pull the front out to gain extra access.
      The pump timing is critical not just a case of a "few blobs of paint". The pump timing needs to be set when the new belt has been fitted using vag com of a decent scanner.
      • mcandmar
        • Apr 2004
        • 5118
        I read that elsewhere too, can you explain in more detail?
        I assumed you either got it right or a tooth off, or is there another menthod of adjustment? I have the vagcom just need a little know how.
        Thanks,
        Mark.
        • urquattro-island
          • Mar 2006
          • 1915
          • Home: Norway Current: Iceland
          easy
          easy job just always go clockwise with the belt (or you will get bent valves).
          japanischer industriabfall nein danke!!
          www.rackeltrim.se Icelandic Division
