(robin hood super spec 2.0l Kseries)
About the grease a brand new propshaft (as my Dad told me it needs to be greased before it goes on). How is best to do this? Theres a grease nipple on it but I'm guessing you cant force grease back down it! Its fitted to the car (as I forgot to grease before hand) and I can remove it from the driver easily but from the gearbox end its pretty diffcult! would it be possible to slide the inside of the proshaft out, stick some grease around it and slide it back into the hole it came out of? ...If you can understand what im getting at there!!!
cheers in advance
_phil
cheers in advance
_phil
