Hi everyone, the idiot who knows nothing needs some more advice...
Having sorted out my running problem we are down to sorting the leaking problems...
Rocker cover gasket shot, leaks alot, removed rocker cover today for fitting new gasket , also wanted to see if my dizzy had a metal gear, and what do you know..... it has a metal gear fitted, therefore I guess the dizzy has been replaced at some time in the past.
My question (which I mentioned in another thread) is should there be any play in the distributor?
With the rocker cover off you can clearly see the whole dizzy shaft and gear wobble inside the head if you wobble from the cap area...
Is this ok?
I expect there to be some movement, but how much is excessive?
Any thoughts guys?
Chris
Is this ok?
Any thoughts guys?
Chris
