privacy glass film
  • vonbeck
    • 2455
    privacy glass film
    does anybody know of a tried and trusted method for removing the above? got stopped by the plod tonight on the way home from work and he was going to give me a ticket which would stop me from using the car he said the minimum limit is 70% mine was err 19% so it has to come off so any advice would be very helpful cheers me dears
  • ericd
    • Nov 2003
    • 1240
    application of heat via hairdryer/heat gun etc
    • madS2
      • Nov 2005
      • 552
      im actually in the same position!Need to remove mine too thought of this idea but will the tint film come off clean or in bits?cheers
      Looking for an S2 ABY
      • terrybullwon
        • Mar 2006
        • 8782
        wall paper striper or a steam cleaner, heat gun?
        Chef
        • Graham
          • 1622
          I'd be wary of using a heat gun, glass doesnt like to be heated up unevenly, call autoglass or someone there must be a simple way.
          • robinm
            • Feb 2005
            • 57
            I've removed the stuff with a heat gun on low setting. Comes off really easily - smells bad though. The glue that is left over is water soluble so just wipe down afterwards with hot soapy water.
            • vonbeck
              • 2455
              got the film off today it just peeled off but the glue was a bitch had to use ipa but job done, cheers for your info guys
              • Ski
                • 2591
                razor and dissolvant
                ABY Coupe
                  Wire brush and dettol ?
                  As a side note, surely plod has better things to be worrying about in this day and age!
                  'k sake...
                  Paul
