my A4 '98 dashboard is out of action
  • panthercz
    • Nov 2006
    • 2
    Hello all,
    I have trouble with my A4 '98.
    Dashboard light, radio backlight and all gauges are out of action.
    Dashboard warning lights like ABS, handbrake etc still work properly.
    I dare to say the problem is that some fuse or ralay has blown, am I right?
    If so, can anybody tell me please where do I find the right fuse?
    If no, what's wrong?
    Thanks for any reply
    P.
  • ~Delta
    • Apr 2005
    • 797
    Welcome aboard!
    Not sure the fuse number, on type B3 / B4 cars, instrument cluster illumination fuse is #12, on A4, number will be different. It should tell you in the instruction manual, or in the fuse box cover?
    Never show a fool a half built house.
    Never underestimate the power of stupid people in large groups.
    Life is like a **** sandwich
    The more bread you have, the less **** you eat
    • panthercz
      • Nov 2006
      • 2
      Thank you for such a quick reply.
      I found this list for A4:
      Fuse # / Description / Amps
      1 / Heated washer jets / 5
      2 / Turn signals flasher unit / 10
      3 / Headlight washer, illumination of glove compartment, engine
      compartment, climate control, automatic transmission, instrument cluster / 5
      4 / License plate light / 5
      5 / Instrument cluster, seat heating, test connection for cruise control, bulb monitor for auto-check control, Automatic transmission display, switch lighting, mirror switches and actuators, airbag warning light, outside temperature indicator, Climate control / 10
      6 / Central locking system / 5
      7 / Anti-lock brake system / 10
      8 / Vacant
      9 / Mirror heating / 10
      10 / Vacant
      11 / Cruise control (automatic transmission) / 5
      12 / On board diagnostic system / 10
      13 / Brake lights / 10
      14 / Interior lights, reading lights, anti-theft alarm system, vanity mirror / 10
      15 / Instrument cluster, power windows, climate control, automatic transmission / 10
      16 / Anti-lock brake system, Anti-Slip-Regulation / 5
      17 / Heated door locks / 10
      18 / High beam right / 10
      19 / High beam left / 10
      20 / Low beam right / 15
      21 / Low beam left / 15
      22 / Tail and side marker right / 5
      23 / Tail and side marker left / 5
      24 / Wiper and washer system / 25
      25 / Blower for heating, climate control / 30
      26 / Rear window defogger, mirror heating / 30
      27 / Rear window wiper / 15
      28 / Fuel pump / 15
      29 / Engine timing / 20
      30 / Sun roof / 20
      31 / Tail lights, cruise control, automatic transmission / 15
      32 / Engine timing / 20
      33 / Cigarette lighter / 15
      34 / Engine timing / 15
      35 / Trailer receptacle / 30
      36 / Fog lights / 15
      37 / Radio / 20
      38 / Luggage compartment light, central locking system / 15
      39 / Emergency flasher / 15
      40 / Horn / 25
      41 / Anti-lock brake system / 25
      42 / Vacant
      43 / Vacant
      44 / Seat heating / 30
      Fuse for Instrument cluster is #5.
      But my fuse #5 is fine ?!? I've checked all the fuses, each looks fine.
      Any suggestion?
      P.
