RS2 Cups size and ET?
  • Coxy
    • Jun 2005
    • 1090
    I should know this but want to be 100% sure.
    Does anyone know the correct size of the RS2 cups.
    17 x 7.5 et ??
    Isn't it 17x7J on the RS2 ?
    Doubtless we'll be corrected soon enough... I definitely can't remember the offset.
    I do know the PCD is 130mm though on the RS2 wheels - Porsche hubs, as opposed to Audi ones.
    Paul
    • Coxy
      • Jun 2005
      • 1090
      Apologies, you are right, 7j x 17". I've got a set on my van which is the unit next to me at work but can't read the darn e.t. and can't find it anywhere on the net!
      • Jas11n
        • 5067
        Offset is something like ET52 IIRC.
        2001 Avus Silver B5 RS4.
        1995 S2 Coupe - sold (sniff)
        • Nuvo
          • Nov 2003
          • 3825
          ET52 was the figure I was thinking of too. Nope it's 55 .
          • Jas11n
            • 5067
            Correction, just checked FA and it states ET55
            • A1QSHIP
              • Aug 2004
              • 975
              Will any Porsche wheel bolt up to the RS2 hub? (not necessarily fit under the wheelhouse). What is the diameter of the wheel centering lugs where the wheel fits on to?
              "Nulla tenaci invia est via"
                Thats PCD of 130mm which I posted earlier....
                Paul
                • Coxy
                  • Jun 2005
                  • 1090
                  There's a 1mm difference between the hub on an RS2 than that of a Porsche.
                  Porka rims need the centre boring by 1mm out if going onto the RS2.
                  • A1QSHIP
                    • Aug 2004
                    • 975
                    So if I had the RS2 hubs turned down before I installed them into the wheel bearing/hub carrier I would not have to modify the Porsche wheels, yes?
                    • volcano rs
                      • Jun 2005
                      • 2265
                      you are a genius sir
                      • A1QSHIP
                        • Aug 2004
                        • 975
                        Yes I have been told that before. It is difficult to build an Ersatz RS2 coupe from across the pond. Lots of questions but thankfully alot of helpful information to be found on this forum.
