Central locking.
  • Si Blythe
    • Jul 2005
    • 346
    Central locking.
    Can anyone shed some light on why my remote central locking has stopped working when I use the key fob. A couple of days ago when I started the car the battery was flat so I disconnected it to charge the battery. I reconnected the following day when fully charged however when I press the key I get the 4 beeps from the system and it doesn't lock but the alarm will go off when I open the door. I have the clifford 650 anti hyjack alarm fitted that worked fine prior to that. The central locking itself still works from the key, if anyone has any ideas then I would appreciate the help. Also how long does the ecu need to learn how the engine works?
    thanks in advance Simon.
    You might leave the S2 fold every so often - but you'll always come back!
  • Dpicariello
    • Mar 2006
    • 621
    Hi, all.
    I have a similiar problem to that described above. I have had the car standing for about 3 weeks. Took the battery out and gave it a full charge last night. However, now the remote central locking isn't working.
    The driver's door lock won't turn with the key but the passengers does so that's how I can lock the car. The central locking works this way but not remotely.
    When I press the key fob the lights flash but not a lot happens.
    One noticable thing is that when I unlock the car with the key in the passenger door lock I hear quite a loud 'horn' noise from the passenger side rear. It's very strange.
    Any ideas?????
    Thanks very much.
    Dan
    • topsparky
      • Oct 2005
      • 2014
      try locking it with the key
      and un locking it with the alarm
      1. SHORT SHIFT KIT
      2. PORSCHE CAYENNE CALIPERS
      3. H & R SPRINGS
      4. BILSTEIN SHOXS
      5. NEW BUSHES AND HP2 STRUTS
      6. UPRATED HIGH OUTPUT COIL PACK
      7. ,3" turbo back s/s/ exhaust
      8. fmic fitted
      • Corey
        Banned
        • Sep 2003
        • 2793
        The key is out of sequence with the car.
        Corey
        01636 822288
        • Dpicariello
          • Mar 2006
          • 621
          Cheers for the replies guys.
          For some reason everything works fine now
          Don't quite know what's going on with it but I'm not complaining!
