rs2 tweeters?
  • rs2315
    • Jun 2006
    • 867
    rs2 tweeters?
    Fellas, can anyone tell me if tweeters in rear door card are in two seperate parts
    ie speaker and speaker cover.
    I know main speaker and cover is a one piece affair.
    Thanks.
    rs2315.
  • AAH!
    • 497
    • Home: United Kingdom Current: Bhutan
    The RS2 rear door tweaters are all in ones, with a retaining ring behind the door card. It is difficult to find direct replacements to fit in the wholes in the door card as they are larger than most aftermarket replacements.
    Angus
    formally RS2 +
    • rs2315
      • Jun 2006
      • 867
      Angus
      Cheers Angus, thanks for info. Door cards off this weekend then, and I'll see what's what.
      rs2315.
      • GT500
        • Jun 2006
        • 2181
        rs2315.
        Sure your up to this?
        I reckon you'll be a dad by then anyway.... and forget all about tweeters!!
        Rob..
        87 UR 20v ABY
        97 S6 Avant
        • rs2315
          • Jun 2006
          • 867
          No bambino yet Rob, but somebody in this house can't reach down to tie their shoelaces and it's not me. Imminent!!!!!!!!!!!!
          I checked search on rear door cards. Looks like undo all screws, including one hidden behind lever opener. Door card then needs to be lifted for removal.
          Is that about right? Any pointers I need to know Rob
          rs2315.
          • GT500
            • Jun 2006
            • 2181
            That is correct.
            WHen i swaped my teeters i left the original grill in place and glued the new ones in.
            works for me! and looks factory.
            Rob..
            87 UR 20v ABY
            97 S6 Avant
            • rs2315
              • Jun 2006
              • 867
              That is correct.
              Cheers Rob, I'll give you and Lou a call when us 2 are 3
