The old girl's just gone through 150k today
To celebrate, I've just put her up on axel stands this evening and am half way through fitting new front wheel bearings, new front CV joints, new front top mounts & retaining nuts, giving the front struts and hubs a lick of paint, fitting a new set of Textar pads to the 996s and have completed an oil and filter change (Valvoline 10W60 fully synth). AND I had it in a local garage earlier this evening to have the rear diff oil changed (using suction!) as I, and then the garage, couldn't get the phooking rear diff plug out - AND I/we TRIED! And I had the garage tweak the exhaust as the cats were scraping everything after I couldn't fit them properly having taken them off to drain the torsen, whist changing the gearbox oil...
PHEW, just another normal weekend in S2 ownership then!
AND, JUST TO TAKE THE ****, I think the bomb's on it's last legs...
In the next installment (w/end Jan 28th/29th):-
151k, a new bomb and possibly fit a 2nd hand PAS pump. Yippee
BUT it's ok cos the Nurburgring is calling!
