Drivers side hub bearing not pressed in fully.
You can see the witness from where the ABS splines on the driveshaft have been pressed on to the hub after torquing the driveshaft nut up
I knew something was wrong when the wheel wouldn't move... at all! Was rather vexing to say the least!
