vin plates
  • topsparky
    • Oct 2005
    • 2014
    vin plates
    does anyone know where i can have some made
    because mine in missing
    also the one in the windscreen aswell
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    8. fmic fitted
  • iain1067
    • 984
    oh that's not good, audi would be the only place i guess.
    iain
    • GT500
      • Jun 2006
      • 2181
      As long as you have your log book with your name on...
      Tag Plates are unbelieveable! Do a google for them.. can't commend them enough.
      I garentee you will be well pleased.
      They could make them for Audi, they are that good!
      Rob..
      87 UR 20v ABY
      97 S6 Avant
      • s2avant
        • 2426
        You would need to provide all your details to the police to get new VIN plates from Audi. There is a mountain of paperwork to go through and the police have to inspect the vehicle before you can order them.
        I'll second the vote for TagPlates. They do spot on replicas. We've used them several times as it's a lot easier than the official route.
        Ben
          <cough> - I'd be really concerned about a car that had the VIN plates removed... even if you have the log book that says you own this car with registration XYZ and VIN 1234 - how do you really know that is the same car ?
          Have you found VIN stickers in the boot or elsewhere which give you some confidence ?
          Paul
          • volcano rs
            • Jun 2005
            • 2265
            dean why don't you buy a legit car instead ?
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              Did you get a V5 with the car? Or did the previous owner not give it to, on that dark night when you picked it up from the motorway service station?
              SS
              • desmo888
                • Oct 2003
                • 390
                Most of the VIN is located on the firewall top center. Some if the digits for the various options have "Z"'s shown but the final digits are there.
                This number is actually stamped into the sheet metal and can not be removed.
                Dave K.
                USA
                1991 e//S2 (home built S2 - the only way to get one in USA!)
                2001 S4
                • iain1067
                  • 984
                  Did you hpi the car before buying??? If not then i can do it for you all i need is the reg no and chassis no to see if they match.
                  iain
