hi just wandering if porsche 911 0r 996 wheels fit an audi s2 lowerwed 60mm they are 18 inch and 265 wide as i think they would look the dogs
porsche wheels help????
Anything is possible,,, just how far do you want to go to fit them?
You would be into widening the wings. bumpers...Rob..
87 UR 20v ABY
97 S6 Avant
1967 Ford Mustang,Eleanor,460ci v8 -
Yes, RS2 hubs are required for genuine Porsche alloys as they're 5x130mm PCD, offset might be an issue too.
Replicas would fit as long as they were 5x112mm PCD ET35 or so. Check with those running 18s with 245 rubber on what offset/spacers they're running.
Don't see 265s working and it's expensive and labourious to fit RS2 hubs, brakes, drive shafts etc. etc. There's a write-up on this that was unearthed recently IIRC. Many cheaper ways to get Porsche brakes on to an S2!
Best bet is to get a good set of 18" replicas with 245 wide rubber and the correct offset. However, even then you might have issues with rubbing on either the track rod ends or whel arches, especailly with a 60mm drop.
HTHCheers'en, AndyC
1994 ABY Coupe - Projekt AlpinweissComment
Just grab a set of H+R hub adapters and fit them on your S2 and then fit any porker rim, clearance is another issue. Coxy s got some 18 s on his lowered RS2 in the night time posting from er last night, just typing that last sentence has made me want to look at those pics again. (pm me ive got a good contact for the porsche h+r adapters)S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
