what is an event lifer?
  • WabTheKing
    • May 2004
    • 2567
    was looking at jobs within race teams and there was one advertised "Event Lifer", now this job looked pretty good - vague but good.
    what i would like to know is WTF is an event lifer!!!!??? cause nobody on the planet (well where i work and my girlfriend) seems to know!!!
    would ring em and ask them but no phone number, just says email your cv
    cheers
    will
  • Keeper of The Kitten
    • Dec 2003
    • 2317
    Sounds like lifing of parts to me, pretty critical job if you don't want failures!
    __MDC__
    Martin Cutting
    • WabTheKing
      • May 2004
      • 2567
      ahh cool, found the def for lifing!!
      sounds like a pretty cool job, - for an F1 team
        • Dec 2003
        • 2317
        Hey Wab any further joy on those bits?
        __MDC__
        Martin Cutting
        • WabTheKing
          • May 2004
          • 2567
          can order the stainless bits if you want, havent got any of the material you specified for the aluminium parts - the stuff i have is a hard grade of aluminium but i have no idea what it is
            • Dec 2003
            • 2317
            Have you got any marked as 2014T6? That would be the stuff.
            Regarding exhaust flange, the minor diameter obviously needs to be the same but the taper can start at 4mm instead of 4.76mm, given that the material is a little thinner. It's not that critical, as long as I know what the starting point of the taper is - I just want to shorten the cone area outside the flange a little bit, and there still appears to be plenty of room to install the nuts on the studs. 12° is to remain the same.
            Cheers!
            __MDC__
            Martin Cutting
              • Dec 2003
              • 2317
              Oh BTW - yes please, let's go with the flanges!
              __MDC__
              Martin Cutting
                cheers
                will
                You sure it's not a shirt lifter mate?
                • WabTheKing
                  • May 2004
                  • 2567
                  dosent really matter so long as i was providing the service and not recceving it
