Good evening!!
If any of you can spare some of your knowledge and expertise it would be most appreciated.
The problem occured today for the first time. I had been driving the car on the motorway for about 1 hour, I went to overtake in 6th(aby) and it misfired, it continued to do this when ever i floored the throttle in every gear, but only as the car approached reaching full boost.
I then went to a friends garage and asked to check for any boost leaks. He found nothing.
The car was then off for about 30 minutes, i then drove home and the car was absolutley fine. It took 45 minutes to get home and did not misfire once in that time. I have since driven the car and it is fine.
I changed the plugs for the correct Bosch ones a month ago and it's been fine till now.
I have seen that people refer to POS when similar things have happened, what are these.
I have heard that the wires to the coil packs are faulty aand maybe need replacing, but my understanding was that if they were at fault the misfire would be apparent all the time.
Any help would be much appreciated..
