Flow rates and gasket 3A engine
  • T2Andy
    • 1903
    Does any one know the flow of a kv engine injector and a 3A engine injector also
    does anyone know the part nos.Reason for asking my mate has just bought a 3A
    engine built by GTI engineering,its a 2.5 with big valves and flowed head and balanced
    steel crank,this is going into his 2.3 coupe 91 .Just wondered which would be the larger injector.of the 2 .Also wanting a gasket set for the same.
    This engine was in a coupe quattro 1987.
  • Jas11n
    • 5067
    Isn't the 3A a four pot Andy? good going to get 2.5 litres.
    Which gasket set? head? rocker etc.
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
    • T2Andy
      • 1903
      It is A 5 pot 3A was stamped on the block it is very much like the KV .The gaskets are
      head sump and rocker.:
      • Jas11n
        • 5067
        Hmmmm, strange this. Looking in FA for part numbers for injectors, gaskets etc for 3A, says it's defo a four pot.
        Autodata coming up with the same. 3A = four cylinder 2.0 litre
        • volcano rs
          • Jun 2005
          • 2265
          if i remember rightly my audi 80 quattro 1990 had this code and it was a 4 cylinder .it has been a while and i can't remember for deffo .
          • T2Andy
            • 1903
            Not sure then ,i know its a five pot just took the head of it it came out of a coupe quattro .
            • T2Andy
              • 1903
              sorry for the confiusion the 2.5 is a KV and the old unit is an NG but they have 3a and 4b
              on the block.
