S6 nutter
Thanks for the porn link John
Modified NRG 298 degree camshafts, lifts 11,5. Camgear from sportquattro, hydraulic lifters from Audi RS4, valveretainers from Audi A-2, Setrab oilcooler, reducers from MOFS.
Ignition: Sportquattro distributor, MSD digital ECU, MSD sparkwires.
Fuelsystem: Autronic SM4, 1600 cc injectors, dual BOSCH 044 fuelpumps, TRC fuelfilter, dual An8 feedlines, single An8 returnline. All hoses and unions from EARL and are stainless teflonhoses with pressed joints. 45 L fuelcell.
Turbocharger: Precision PT76 with antisurge. exhaust- and inletmanifolds from www.furans.se and wastegate from www.martinssonracing.se. Blow-off valve from KL.
wheel powerstats: 750whp 7500rpm
Transmission: permanent fourwheel drive quattro generation 1, sinter clutchplate and Audi S1 pressureplate. Lockable intermediary and rear differentials.
High-performance chassis: Stock shockabsorbers, chassis lowered 50 mm, front swaybar removed, Roadkit from KL including all wishbonebushings and topbearings.
Steering: Servounit removed
Tires and rims: BBS 15" with 205/50/15 BF Goodrich Dragradials for racing
Avantgarde 17" rims with 225/40 for cruising
Topspeed: Gearbox with longer gearratios: 245 km/h
Gearbox with shorter gearratios: 230 km/h
Where could i get my mits on a sport quattro dizzy? would it run with the motronic?ChefComment
You missed these facts off Terry
Engine: 5 cylinder Audi code 3B. Bored block with pistons from JE. Modified stock connecting rods, balanced crankshaft from VW Santana, Sportquattro cylinderhead reworked by www.topplocksverkstan.se .Comment
Imagine the poor guys look when he gets the car back with no tread left...
