S2 avant boost problems
  • Rik
    • Aug 2006
    • 41
    Hi guys hope you can give me some ideas of what my problem could be i was travelling up the motorway in sixth i had been travelling for about an hour and had had no probs whatsoever when i put my foot down as it went past 0.5 bar it cut out and lost power it did this in every gear i stopped and had a check under the bonnet but couldn't see anything untoward so had a coffee got in and started off on my journey everything was back to normal the boost was fine then a little later down the road it started again it was fine if i held it at 0.5 but anything over that i would lose all power! ive had it chipped by s2central if your out there have you got any ideas??
    cheers rik
  • terrybullwon
    • Mar 2006
    • 8782
    Rik does this only happen at WOT?
    i guess you normally see about 1.5bar with a home fry?
    It could be the sign of a failing coil pack, or just a pesky boost leak? have you done the Mark H mod its always worth doing as the o-rings fail.
    Try a bit of gas leak detector spray on all the boost connections and then put a bit of load on the engine
    Cheers James
    Chef
    • YELL MAN
      • Dec 2005
      • 536
      • Country: Shetland Islands
      Mine does this from time to time but giving the MAF a good clean with alcohol isopropil usually sorts it out.
      1994 Indigo Blue S2 coupe
      1994 80 Avant 1.9 TDI
      2005 Yamaha Fazer 1000
      1953 AJS Model 18S
        Betting is on the good old knock sensors mate.
        Identical sympthons to other posts.
        • Rik
          • Aug 2006
          • 41
          sorry for being stupid but what is the maf?? and where!!??
          • topsparky
            • Oct 2005
            • 2014
            its the air flow meter rik
            is sits between the air box and the maf hose
            1. SHORT SHIFT KIT
            2. PORSCHE CAYENNE CALIPERS
            3. H & R SPRINGS
            4. BILSTEIN SHOXS
            5. NEW BUSHES AND HP2 STRUTS
            6. UPRATED HIGH OUTPUT COIL PACK
            7. ,3" turbo back s/s/ exhaust
            8. fmic fitted
            • Rik
              • Aug 2006
              • 41
              cheers buddy!!
