Instrument Cluster Prototype
  • s2_bo
    • Oct 2005
    • 6067
    Got bored today so i modded one of these and came up with this:
    91 S2 coupé - RIP
    98 S8 - Luxury barge
  • s2_bo
    • Oct 2005
    • 6067
    Another.
    91 S2 coupé - RIP
    • s2_bo
      • Oct 2005
      • 6067
      I have redone all the wiring at the rear of the cluster as the boost gauge internals were to long.
      Tomorrow i will convert my S2 cluster like this and will move 4 the now missing info/warning lights to the top left and right side of the cluster.
      Should look sweet when its all done
      Cheers.
      Bo
      91 S2 coupé - RIP
      • HPmuirt
        S2Forum April Fool
        • Apr 2005
        • 3014
        Hey Bo, I have often though about doing that too, although I had planned to maintain the temperature display and move the gauge up a tad.
        The question is, what is the minimum number of warning lamps in that area that we actually use/need? The reason is, that if you look from the back, you will see that on either side of the 2 main gauges (above the temp and fuel gauges) there are a pair of unused lamp cut-outs.
        It should therefore be possible to move at least 4 of the central warning lamps over.
        Wayya fink?
        Cheers n
        Si
        Subtle mods here and there
        2011 A5 3.0 TDi - Lava Grey
        • s2_bo
          • Oct 2005
          • 6067
          Good idea Si,
          I was thinking of having the warning laps somewhere else outside of the cluster.
          I was only using 4:
          Hand Break
          ABS (Off)
          Oil
          Main Beam
          None of them are really that important though, so i have done away with them for now.
          I figured that:
          Hand break - Its quite obvious when this is engaged.
          ABS - This is only off is i switch the ABS button on.
          Oil - Can be monitored by the other two Aux Gauges and the Auto Check also blinks up if anything is wrong.
          Main Beam - Again its quite obvious when these are on.
          I will eventually move them somewhere.
          Im done for now though
          I know its the wrong colour
          91 S2 coupé - RIP
          • s2_bo
            • Oct 2005
            • 6067
            one in the dark:
            I have wired this in so that the brightens is adjusted with the rest of the cluster.
            91 S2 coupé - RIP
            • merlin's S4
              • Jan 2005
              • 1539
              Top job! Nice one Bo!!
              • topsparky
                • Oct 2005
                • 2014
                that looks gr8 bo
                1. SHORT SHIFT KIT
                2. PORSCHE CAYENNE CALIPERS
                3. H & R SPRINGS
                4. BILSTEIN SHOXS
                5. NEW BUSHES AND HP2 STRUTS
                8. fmic fitted
