Rs2 Ic Fitting
  • s2 rich
    • Dec 2006
    • 272
    Rs2 Ic Fitting
    Hi all recently aqquired a rs2 ic (thanx laser) and first of all i noticed the pipework was different from my standard 3b ic. I was just wandering if it would be easier to buy an rs2 ic hose or just get a 90 degree bend silicone pipe and do it that way what have other people done ??
  • Ross
    • Aug 2005
    • 3399
    On my 3B i had samco hoses; the 3B hose has a bend in it whereas the RS2 IC hose is longer and the endpipe is angled - whereas the rs2 pipe is slightly shorter with no bend.
    Thus, I simply cut the bend off the 3B hose and it was a straight fit to the RS2 IC.
    HTH
    Ross
    • s2 rich
      • Dec 2006
      • 272
      thanks for the help a nice job for the weekend
      • denniselbows
        • 740
        you'll need to make a new bracket to bolt it up with as well.
        never set your expectations to high that way you are never disapointed
        • s2 rich
          • Dec 2006
          • 272
          it comes attatched to the cross member i take it the bolt holes are the same for the rs2 and the s2
          • denniselbows
            • 740
            if you have the rs2 cross member then scap that last coment
